can't hear charging sound when I plug it in
(Topic created on: 03-17-2017 10:21 PM)
midnightstarr
Hello,
I can't find any help for this issue. My sound is working fine when it comes to everything else on my Samsung Galaxy S6. But when I plug it in to charge, I don't hear that sound that it is charging. I do see the thunderbolt. How do I fix this?
3 Comments
Brando
Go to settings > Sound and vibrations > charging sound. Make sure it's on and for the sake of it turn it off than on. Then go to volume which is in the same setting area and make sure all volume levels are at max.
sumday
Beginner Level 3
Thanks it was the volume setting that had me 👍
AlexT32
that happened to me this morning I wasn't hearing the sound when I plugged it in. I restarted the phone and it worked
