Resolved! Solved
Devices Using My Mobile Hotspot
(Topic created on: 05-26-2022 10:32 PM)
Atsirt
So I know how to view the devices connected to my mobile hotspot, question is how can I boot someone from my hotspot? Is there a quick remove or do I have to change the password or something? Using S22 5G with Android 12. Thanks!
3 Solutions
user11
Just change the password for your hotspot
vgndude08
Indeed, I think changing the password should do the trick.
Brantley
Hi. Yes, please change the hotspot password.
3 REPLIES 3
user11
vgndude08
Brantley
