Resolved! Solved
Device using my mobile hotspot
(Topic created on: 09-11-2022 04:55 PM)
Devilgod
So I know how to view the devices connected to my mobile hotspot , question is how can I boot someone from my hotspot ? Is there a quick remove of do I have to change the password or something ? Using S22 5G with Android 12. Thanks !
Axton
Hi, we suggest you Just change the password for your hotspot and see if it works.
4 REPLIES 4
Axton
I think you need to turn off mobile hotspot, then reset password. No other better way.
Axton
Hi, we are glad to assist you. Kindly contact us back, if you require any help in the future.
RedDogRabbit
Just turn off the Mobile HotSpot.
When you turn the HotSpot on again, You'll see a Notification popup, "asking" for permission & verify the code.
No one can access it unless you grant permission, even if you don't change the password.
