Edge Panel query in S23 o
(Topic created on: 10-18-2024 06:57 AM)
VineelKumar
How can remove first 2 options in Edge Panel?
After Latest update these came up and I can't remove them.
7 REPLIES 7
RedDogRabbit
You should only see the items you selected when you swipe to open the Edge Panel.
VineelKumar
As you can see from above image, I can't remove them (there is no remove option).
They added directly after Latest update.
Helenna
Hi VineelKumar,
Since you have mentioned there is no option to remove option, please try to disable and re-enable the Edge panel. Then check if your'e able to remove first 2 options in Edge Panel.
Thank you.
VineelKumar
Thanks for replying. I have disabled and re-enabled edge panel. Still same issue, I can't remove them.
RedDogRabbit
Open Edge Panels & Click on the "Apps" Panel & Toggle these two Off & then they are removed.
VineelKumar
Thank you very much buddy, they are gone now.
RedDogRabbit
Happy to help 👍🏻
