finger print sensor not working samsung ultra s23
(Topic created on: 11-30-2023 03:43 PM)
Members_t01zSz9
i cant use fingerprint sensor at all. it showed "fingerprint sensor not working if this keeps happening, restart your phone"
i have tried all the suggestions on the internet unless rebooting my device. Please help me to solve this problem.
3 Comments
RedDogRabbit
Open the Samsung Members app & Click on Support > Phone Diagnostics and run the Diagnostics for the Finger Print Recognition. See if you get any error messages.
You can try Booting into Recovery & Wiping Cache, but I don't think that will help. If there is a hardware issue, then visit a Samsung Service Centre to get it checked out by a tech.
You could always Backup your device with Smart Switch & Factory Reset.. But again, if it is a hardware issue, that won't help.
Helenna
Hi, just to confirm have you tried the steps as suggested by the RedDogRabbit ?
Please let us know if you are still facing the issue after performing the steps.
fingerprint
We are two People with the same phome with the same problem occured 1 month apart. Fingerprint stopped working. Samsung s20fe. How can we fix this
