Fonts
(Topic created on: 08-16-2024 08:35 PM)
paneerkepakode
Is there any way to force my custom font on all thr apps? Like reddit, Twitter, Snapchat etc?
10 REPLIES 10
RobertZ
Settings->Display->Font size and style. Pick your font style and size.
That was not the question
RobertZ
That was the answer.
Lmao what? That's not even what I asked 😂 "that was the answer" you think you did something there 😂😂😂😂😂
RobertZ
You ask for free help and then give attitude when it's given. Good luck.
That's literally not what I asked tho, I know how to change a font but that wasn't the question, the question was how to force the chosen font over apps like Twitter and Snapchat where my font doesn't show, maybe next time read the question better before thinking someone is showing you attitude. Wish you the luck you deserve
Kirbymail
I have the same question
Yeah, idk my Twitter and reddit. It looks so ugky w the font they have for the app
Helenna
Hi paneerkepakode,
It's not the problem with the font, seems like it's the problem with the apps. They aren't supported to use this kind of font.
We will forward your suggestion the relevant team for review. So that, they will look into it and hopefully it will be added to the next update.
Thank you.
