Wifi issue is trying to connect but the 5g+ will not switch
(Topic created on: 08-19-2024 09:38 AM)
demontiger
Wifi issue is trying to connect but the 5g+ will not switch on s24 ultra
4 REPLIES 4
RedDogRabbit
Couple of things to try:
Go to Settings & Search for "Reset" and Reset the Network Settings on your device.
Go to Settings > Connections > WiFi and Click on the 3 Dot Menu Top Right > Check the Settings in "Intelligent WiFi & Then Click on Advanced Settings in WiFi > Toggle ON the obvious selections in both.
Reboot and see if the issue is resolved for you.
demontiger
Thx will try
Helenna
Hi demontiger,
Have you tried the above steps? Are they worked for you to solve the issue on your device?
demontiger
Yes it did work with the steps
