Having low volume issues on AirPods with my Galaxy S21 Fe
(Topic created on: 12-20-2022 06:10 PM)
Juhyun
Tt was working completely fine until today. I've had my absolute volume turned off since the first day I bought the Airpods (2nd gen)
Does anyone know how to fix this problem?
4 Comments
Helenna
Hi, what is the volume issue your'e facing with while connecting the  Airpods to the S21fe?
Is the problem happening with only Galaxy S21 fe?
Have you tried connecting them to the other device and check the issue?
Juhyun
Worked fine with S10 and with my Acer laptop. And the issue is that the volume is way too low when playing music or just any sound in general
Nylah
Hi, just to be sure is that are you unable to adjust the volume for the Airpods only with your Galaxy S21fe?
Have you tried to disconnect and reconnect them again.
Juhyun
Yes, literally tried everything and it's still low.
