da6ixbarber
01-03-2017 03:15 PM in
so I got an Honda accord 2013 and the metadata is not working it comes on from time to time but does not stay for long does anyone know what's going on with this ???
4 REPLIES 4
datbananaboi
01-03-2017 04:28 PM in
maybe try pulling down the notification bar and tapping Quick Connect, and find your car. then connect and try again
Nick_from_Samsu ng
01-11-2017 01:06 PM in
Hi @therealpereira, to help us troubleshoot this error, can you submit a device error log? From the Samsung Members application, tap the “Feedback” icon. From the “Questions/Errors” tab, tap the Pen icon and then submit an “Error report”.
Nick_from_Samsu ng
01-11-2017 03:24 PM in
(make sure you submit the error log when the symptoms occur)!
andyglb
01-21-2018 03:05 PM in
I'm having the same issue with my Subaru
