Help with developer options please UltraS21+
(Topic created on: 06-13-2022 09:34 AM)
muskokacam
Looking for tips  or resources that assist with some useful settings that can be adjusted for best performance on my Gakaxy S21 ultra + using the developer options.
Anything helpful is appreciated. Advice not to is understood but not warranted. Not looking to ruin phone, just to maximize its potential.
Thnx
3 REPLIES 3
Helenna
Hi, for better performance please try the steps given below :
Use Device care to optimize your apps. Navigate to and open Settings, and then tap Device care. Tap Optimize now. This will delete residual files and clear out memory.
Uninstall unused apps. Navigate to the Apps screen on your device. Touch and hold the app you would like to uninstall. Tap Uninstall.
neals
Turn animations down or off in dev settings will be alot more responsive
muskokacam
Thnx a lot. Any other ideas to maximize the phone?
