Another problem with series S
(Topic created on: 06-17-2022 03:59 PM)
wilh
Nice now Samsung galaxy S20 ultra
5G won't charge what is the problem now huh
10 REPLIES 10
jbldee
Get a new charger
RedDogRabbit
Did you try a simple Reboot?
Did you try opening the Samsung Members app Click on Support > Diagnostics and View Tests & test the USB port?
wilh
it's good I clean up the data from my battery apps
RedDogRabbit
So it's charging now?
That's an unusual fix though.
wilh
yeah everything is fine now I also clean up my USB port who was maybe dirty
Helenna
Hi wilh, that's good to hear that your phone is charging again.
We recommend you to use a soft cotton swab to clean out your charging port.
wilh
& my bloc for my phone is a super fast charging, but my phone take alot of time to charge & that's the original one that come with my phone....🤔
Helenna
Hi, it is possible that a third-party app is causing the issue. Please perform safemode and verify if the issue is solved.
To enter Safe Mode, please perform the following:
1.First, completely power off the phone.
2.Then, power on the phone and when the Samsung logo appears, press and hold down the Volume down key.
3.If done correctly, "Safe Mode" will display on the bottom left corner of the screen. If "Safe Mode" does not appear, repeat the steps above.
4.Once you are in Safe Mode, you can remove the third-party app that is causing issues on your phone.
5.To exit Safe Mode, simply restart your phone and it will reboot normally.
wilh
I when in save mode & was is that third-party app .....
