How to display time and date in top corner of lock screen or always on widget?
(Topic created on: 10-18-2023 07:55 PM)
Jake46
Is there a way or a widget or lock screen theme that puts the time and date in the top right corner? They all seem to have the time and date in the centre. And it can't be dragged or moved to top right corner. I want the time and date to show in the window of my Samsung wallet case which has an opening in the top right.
5 REPLIES 5
Deeezzyyy
If the Samsung wallet case is legit, it should be automatic once you put the case on and there's nothing you need to do to change it.
Jake46
I thought so too, but I must have changed a setting or restored a back up on my new S23 phone and it's not displaying the time and date in top right like the description shoes. I may just return the case if I can't solve this.
https://www.samsung.com/ca/mobile-accessories/galaxy-s23-smart-view-wallet-case-black-ef-zs911cbegca...
Deeezzyyy
I found this online. Put the case on, and scroll through your settings to see if you have the "cover screen" section that pops up.
If it is not there, try removing the case and putting it back on. Maybe it'll detect it afterwards.
Might be able to play with the settings from thereScreenshot_20231018_232627_Samsung Internet.jpg
Jake46
Thank you kindly, but alas, it didn't work. I tried.
Jake46
I figured it out - the case was defective. Went to return the case and the suggested I try a new case. The new smart wallet case worked. The case has a magnet in the top right and the phone recognized it. Yay.
