Resolved! Solved
Lock screen info to display.
(Topic created on: 06-08-2023 08:34 AM)
thebrez
Good day all.
 I'm trying to find the option to display on my lock screen . How do i add contact info.
I have an S205g.
Thank you kindly
RedDogRabbit
Click here & you'll see the next screen where you can add your Contact Info.
11 REPLIES 11
RedDogRabbit
Go to Settings > Lock Screen & on the left panel, click on Edit & you can add your Contact Info there.
thebrez
Hi,there is no option to edit
RedDogRabbit
Can you post a screen shot of what you see, when you go to Settings > Lock Screen?
What device do you have, because you should see this.
thebrez
Ok, Screenshot_20230608_132436_Settings.jpgScreenshot_20230608_132419_Settings.jpg
RedDogRabbit
thebrez
I have an S205g
thebrez
Thank you so much . Success !!
RedDogRabbit
Happy to help 🙂
RobertZ
Itttt's 🦜 time!
