Resolved! Solved
MMS issue on wifi
(Topic created on: 09-02-2020 01:58 PM)
aliteepu
Hi All.
S10+ is not downloading any incoming MMS via wifi..but as soon as i switch to data.it work instantly. Checked all the settings..restarted. any guess. Thnx
3 Solutions
Ok, did some research on Rogers forum. Technically, MMS does require data connection. That means even you connected to WiFi, you still need data enable at the same time. If you turned data off and just WiFi at home, MMS will not work.
Also, in this forum. Moderators have been mentioned that data needs to be turn on for MMS operations.
ctangabc
Tallman is correct, MMS requires data connection to send/to receive messages.
Kinsley
Hi aliteepu,
Yes, To Send/Recieve an MMS, mobile data need to be active. If it hasn't been turned on, you will not be able to send or receive any MMS. I hope this information will help you.
10 REPLIES 10
In the old days, MMS requires data to send and receive. But recent years, seems to be changed. I realise that MMS can be send and receive over WiFi. Can this be carrier problem? Are you using Rogers?
Oh...do you have WiFi Calling feature? Maybe you need this plan in order to send MMS over WiFi?
aliteepu
yes with rogers..but i called them. they said everything is fine at there end
Have you turned off mobile data and just WiFi? You still need data turn on in order to send over WiFi.
aliteepu
yup..at home only wifi..i dont use both at the same time..but for MMS..hv to use data..i checked mms on apple phone..doesn't need data to download..wifi is enough
ctangabc
aliteepu
thnx...
Kinsley
Hi aliteepu,
aliteepu
thnx kinsley..
