MGBL4K
			Beginner Level 4
04-30-2025 05:52 AM in
						Hi everyone
I am having trouble with auto rotate on my one ui 7 update recently and I cannot find the auto rotate in the control center. I am coming from iphone so I can getting used to android but can someone please help me? Thanks!
		4 REPLIES 4
			Goldenseal
04-30-2025 06:05 AM in
						The button circled in red is the Auto Rotate button. If you don't find it in your control centre, you can click the small pen icon in the top right corner to add it.
 Helenna
			Helenna
04-30-2025 06:09 AM in
Galaxy SHi MGBL4K,
If the auto-rotate icon is missing from the Quick Settings, it could be hidden or accidentally removed. Here's how to check and restore it:
- Swipe down to open the Quick Settings Panel.
- Tap on the three vertical dots in the top-right corner and select Edit.
- Look for the Auto Rotate icon and drag it back into your Quick Settings.
- Once restored, try tapping it to enable auto-rotation.
Thank you.
			Ray1
			Expert Level 3
04-30-2025 06:13 AM in
Galaxy SThe auto rotate button changes to the word Portrait when disabled so look for Auto Rotate or Portrait because it is the same button
			MGBL4K
			Beginner Level 4
04-30-2025 06:18 AM in
						Thank you everyone!
