Problem after One UI 6.1.1
(Topic created on: 09-29-2024 04:09 AM)
Ayaank7
Yesterday i updated my S22 ultra to one ui 6.1.1 after that my device started lagging like hell it is not working smoothly as before. It is randomly rebooting and giving errors like System UI isnt responding. Please help me fix the issue.
3 REPLIES 3
RedDogRabbit
a) Boot into Recovery & Wipe Cache.
b) Backup your device with Smart Switch & Factory Reset.
I always Factory Reset after EVERY Android Version Update, and I've never had any issues.
Kirk_Godfrey
That's a good idea, I think I'll adopt that practice 😊
Helenna
Hi Ayaank7,
Yes, it is advicable to perform Wipe cache partition after every update. Wiping the cache partition can often help improve performance and fix minor bugs without affecting your data.
1. Hold the Power button and Volume Down to open the power options where choose the Power off.
2. When the screen goes dark press the Volume Up and Power keys together.
3. Let go of all held buttons when you see the Recovery mode on the screen.
4. Then you should select Wipe cache partition. Use Volume Up to navigate and the Power button to accept it.
5. Choose Yes and press the Power key to confirm that operation.
6. After that select Reboot system now with the Power key.
If that doesn't work, then please perform back up and factory data reset on your device and check if it fixes the issue.
https://www.samsung.com/ca/support/mobile-devices/perform-a-factory-data-reset-on-your-galaxy-phone/...
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-back-up-and-restore-data/
Thank you.
