S21 ultra 5g smart clear view cover not working
(Topic created on: 07-16-2024 01:58 AM)
joakimlind
S21 ultra 5g smart clear view cover not working after June security update
I have tried the different ways to workaround the problem
2 Comments
Helenna
Hi joakimlind,
Sorry to hear the buggy experience. Have you tried changing the battery settings to unrestricted and then restart the device.
If that doesn't work, please try Booting into Recovery by Wiping Cache partition and check if it resolved the issue.
1. Hold the Power button and Volume Down to open the power options where choose the Power off.
2. When the screen goes dark press the Volume Up and Power keys together.
3. Let go of all held buttons when you see the Recovery mode on the screen.
4. Then you should select Wipe cache partition. Use Volume Up to navigate and the Power button to accept it.
5. Choose Yes and press the Power key to confirm that operation.
6. After that select Reboot system now with the Power key.
Thank you.
joakimlind
Unfortunately that did not solve the problem.
Kind Regards
Joakim
