S22 plus weird lag, freezing, and snapchat record lag
(Topic created on: 07-24-2022 07:33 AM)
JacobScudds
So I've had this s22 plus for 2 weeks and it has been great. But the "optimized" snapchat is horrendous. The frames skip when I first start recording. Not to mention the general UI sometimes will freeze. Any tips?
3 REPLIES 3
RedDogRabbit
I don't use Snapchat, but I'd remove it from being Optimized. Sounds like that's where the issue is coming from.
You could also try clearing cache & data for it & Reboot.
mr_x
man im also facing literally same problem , the day i got this phone ive just suffered
whats wrong with this phone,its super laggy although i have everything cleared and optimized but still disappoints me everytime when i open camera app
it takes forever to open 🙂
Axton
Hi JacobScudds, we sincerely apologize for the inconvenience caused to you.
We suggest you check for the software update.
Step 1. Go to Settings > Software update.
Step 2. Tap on Download and install.
Step 3. Follow the on-screen instructions.
If you haven't tried to clear the Cache on the snapchat app , please follow the steps given below :
Settings >> Apps >> snapchat app >> Storage >> Clear cache (bottom right button). tap Clear data, and then tap OK.
This will completely wipe the app and reset it to the original settings.
