03-13-2024 09:23 AM in
03-13-2024 09:53 AM in
Galaxy SHi, we are sorry to hear that the software update caused the battery draining issue.
Please Go to Settings > Battery > Scroll down to see which apps in Battery Activity are draining your battery.
Put those unused apps to sleep, and Restrict or Optimize the ones that are draining it.
Also, we recommend you to perform Wipe cache partition on your device after the update. This will not erase personal data on the phone. It deletes temporary cache files in the phone.
Turn off the device > Press and hold the Volume Up key and the Power Key > When the Android logo displays, release all keys.(("Installing system update" is displayed before displaying the Android system recovery menu options) > Press the Volume down key several times to highlight “wipe cache partition.” > Press the Power key to select > Press the Volume down key to highlight > “yes” and press the Power key to select. When the wipe cache partition is complete, “Reboot system now” is highlighted.
Press the Power key to restart the device.
03-13-2024 10:09 AM in
Galaxy SThanks for the response. I really appreciate it.
03-14-2024 12:26 PM in
Galaxy S- Mark as New
03-14-2024 12:55 PM in
Galaxy SI Wipe Cache after every single OTA, and Factory Reset after EVERY Android Version Update.
I've never had any issues following this process.
03-13-2024 10:00 AM (Last edited 03-13-2024 10:06 AM ) in
Galaxy S~ 6 hours of SOT & 26 hours, 18 minutes on battery with 8 hours 17 minutes remaining on my S23 Ultra February Security Patch.
I'd suggest that follow Helenna's suggestion of Wiping Cache, along with verifying what apps are using the battery. Check especially apps that are running "Unrestricted".
03-13-2024 10:10 AM in
03-13-2024 10:05 AM in
03-13-2024 10:13 AM in
Galaxy SI haven't noticed any negative difference since the February Security Patch.
Anything else changed, ie: New apps etc?
03-13-2024 10:22 AM in
