S8+ Red hue screen problem
(Topic created on: 04-25-2017 04:08 PM)
Vader
Does anyone have a solution for this?
I already color balanced it by diminishing the red but problem still persists.
Also I got a Samsung update popup message today but mistakenly swiped it before pressing update and now it's gone. How can I get it back?
Thanks.
9 REPLIES 9
Jonathan34
Go to settings-software update- manual update
Also I know they are supposed to be pushing the red screen update out soon don't know if that's the update you're getting now or if it's coming soon
Vader
I tried manual update but there was nothing in the queue.
JohnnyK
I don't believe that this update is an android update. it is Galaxy Apps critical update. large update 943MB is the size of it
Moderator_
Hey @Vader, if you can't adjust the screen tint from your display setting please contact your local Samsung Service Center (http://www.samsung.com/ca/support). –Nick
Vader
I was at a Samsung Store today in Toronto and explained the issue, they just told me to wait for the software update.
JohnnyK
I have the same issue; I got a popup with 943MB for critical update and it asked to accept or deny it ; unfortunately I wasn't connected to WiFi so I pressed the home button to connect to WiFi. after I pressed the home button; the update message disappeared and couldn't receive this update message back. this is not an android update, this is Samsung apps update
Vader
There must be a way to request these updates again, Nick?!
If you guys were not connected to wifi during this update, it should reappear in a day or so. I know sometimes I have not been connected to wifi, and I have rejected an update, it prompted me again the next day.
Vader
I finally got the update called Device Quality Agent which had a size of 943kb but it has to do with WiFi and nothing to do with fixing the screen.
