S9 is auto rejecting calls from private #'s going to voicemail. How 2 stop?
(Topic created on: 10-13-2020 02:47 PM)
Terrordog
Beginner Level 4
5 REPLIES 5
Halston
Hi Terrordog,
Please contact your SIM card provider so that they will help you accordingly.
Hi Terrordog, please check the following :
Open phone app → 3 dots on top right→ Settings →Block numbers
Do you have block unknown / hidden number enabled? If you do, turn it off.
Also try turn off Caller ID and spam protection.
Terrordog
Beginner Level 4
Hey Tallman, thanks so much! It was the hidden/unknown number enabled.
Now disabled.
Awesome!
Happy to help 😄
Halston
Hi Terrordog,
Glad to know that your problem got resolved. Please take a minute and click on Accept as Solution to help other members with the same query.
You can accept the comment as a solution by Clicking on 3 dots on the right side the comment >> Tap Accept as Solution.
Thanks to Tallman for your information.
