Samsung S10 not charging at all after connector was hot.
(Topic created on: 10-13-2020 08:21 PM)
manuel_chacon
My Samsung S10 is not charging at all , and I have had it for only two months , I was charging it and I noticed that the charger connector got hot and after that the phone is not charging, the cable is not the problem because I tested that cable
4 Comments
Ray1
Do you have a wireless charger??
That would be your cheapest way of fixing your charging problem unless your phone is still under warranty in which case you should take it for service.
Halston
Hi manuel_chacon,
There are several reasons why your device might not charge, and most can be fixed without any extra support. The most common reasons for a device failing to charge are:
Faulty cable, charger, socket, or adapter
-Dirt or debris in the charging port
-Third-party apps interrupting the charging
-The software update is required
-It is recommended to keep the device software to the latest version.
Follow the below steps:
- Use an official charger
- Check for damage
- Try a new cable
- Try a different power source
- Clean the charging port(Try gently blowing into the charging port to remove dust and debris.
Please note: Do not insert any object into the charging port. This can result in damage to the charging port.)
- Check for water and moisture.
- Try with the different chargers and try the connector with different devices and check.
- Also, try with the wireless charger if available.
You could also try performing a soft reboot. Hold the Power and Volume Down keys.
Get back to us with the result.
mytech
Expert Level 3
That's a great answer @Halston 👍
I love how you always give lots of detail ✌️
I would just move the
"-Check for water and moisture"
And
"- Clean the charging port(Try gently blowing into the charging port to remove dust and debris.
Please note: Do not insert any object into the charging port. This can result in damage to the charging port.)"
To the 3rd and 4th spot under
"-Check for damage"
Then move
"-Use an official charger"
Below those
Bc if the port is mucked up
It doesn't matter what chargers/ cables or power source your using 🤷
Halston
Thank you mytech, The way you share information is 👍 and helping community members in a different and humorous way feels good and bring smiles to our faces.🙂
