Samsung A51 Swollen Battery
(Topic created on: 05-06-2021 07:05 AM)
AdityaSharma
I purchased Samsung A51 on 21 Aug, 2020 and today is 6 May 2021 and my phone's battery is swollen so much that the back cover has got a small dent\slight lining because o which my edge of my phone is uplifted and is about to get de-attract fom my phone. Please some help me.
3 Comments
This does not sound good as this may lead to an explosion of the battery. I would recommend getting your phone to a Certified Samsung Electronics shop ASAP.
Valeriya
Hi, Please could you let us know if you are using an unauthorized charger for your device? Also, are there any physical or liquid damages found on the device? However, please share the screenshots of the device for further assistance.
ednaL
Sometimes that means the battery is running nonstop, apps in background and could be Spyware. Check data use, etc. Bloated batteries, cases warping a sign of constant battery use
