Samsung Flow Phone Keyboard issue S9
(Topic created on: 04-27-2019 12:39 AM)
LDConix
Not sure if it was a recent update to Flow but now my keyboard on the phone will not pop up when connected to Flow screen sharing and this makes it impossible to use emoji's when messaging... Is there a way to enable this or is it some "feature" that was removed?
3 REPLIES 3
TheWeatherbuzz
Did you ever solve this issue? I'm having the same problem with my Note 9.
TWE
Beginner Level 3
Same - Just started using Flow, and love everything about it except this and the fact that I cannot use Mobile as a connection option.
Samsung_7hUvnoW
Struggling for few hours, i finally found the way to solve it.
Go to setting - General Management - Language and Input - On-screen keyboard - Default Keyboard - Swipe to ON the On-screen keyboard.
Then you will able to use the keyboard (physical one or the on-screen one) on both your smart-phone and PC. But of course the view will be limited as the on-screen keyboard is taking up some space.
Hope this helps.
