samsung s9 wireless printj g issues
(Topic created on: 12-28-2020 09:48 AM)
Phil1956
Have a samsung s9 printing to hp 8600 printer printing it is spooling taking so long didn't before on s7 and on my wife's apple her printing the same page took 17 seconds while the s9 took 53 seconds
Suggestions
Halston
Hey Phil1956,
Make sure that the phone is updated to the latest version. If you are facing an issue with the Galaxy device, it needs to reboot the device. This can be done by turning off the device and turning it back on. It will fix many issues.
Go to Settings> Connections> More connection settings> Printing.
Configure settings for printer plug-ins installed on the device. You can connect the device to a printer via Wi-Fi or Wi-Fi Direct, and print images or documents.
Note: Some printers may not be compatible with the device
Adding printer plug-ins:
Add printer plug-ins for printers you want to connect the device to.
1. On the Settings screen, tap Connections > More connection settings > Printing > Download plugin.
2. Search for a printer plug-in in Play Store.
3. Select a printer plug-in and install it.
4. Select the installed printer plug-in.
The device will automatically search for printers that are connected to the same Wi-Fi
network as your device.
5. Select a printer to add.
To add printers manually, tap three dots in the top right corner> Add a printer.
