system ui tuner
(Topic created on: 05-28-2017 04:56 PM)
RyAn67
Does anyone know how to enable system ui tuner? I tried holding down the gear tool in the notification center but it didn't work.
13 REPLIES 13
What make of phone do you have? Is it the S6, S7/S7+ or the S8/S8+ that you are trying to enable the system ui tuner on?
RyAn67
s6
Another question that just came to mind. Are you still on the Android Marshmallow software or upgraded to the Nougat 7.0 software?
RyAn67
I upgraded to nougat
here are the steps to enable the system ui tuner in Nougat 7.0
1 - pull down notification shade
2 - tap and hold the settings cogwheel for about 10 seconds
3 - you will be taken straight to the settings app with a prompt saying that system ui tuner has been enabled.
You can access the new entry by scrolling all the way down in settings.
Hope this helps. Best of luck!!!!
RyAn67
thanks but I already tried that and it didn't work.
Then as far as I know there may not be much more that can be done to enable the system ui tuner or the phone just does not have the ui tuner function.
so where did you get those steps from, because they dont seem to work on 7.01
I found these steps on a website called wccftech.com
