04-08-2022 11:52 AM in
Galaxy S- Mark as New
04-08-2022 08:27 PM in
Galaxy SAs I know all my phones after factory reset, WiFi calling set back to disable. If it is disable, that really strange that WiFi calling running at the background and drain battery.
04-09-2022 12:58 PM in
04-09-2022 02:06 PM in
04-09-2022 02:12 PM in
04-09-2022 02:13 PM in
04-09-2022 02:16 PM in
Galaxy SAre you using it in Canada?
04-09-2022 02:19 PM in
04-09-2022 02:32 PM in
Galaxy SYeah I really don't think that it should, just trying to think of any explanations.. There's no difference in the actual hardware between the Canadian & US S21 series...
We've been Flashing the US Betas on our Canadian devices without any issues, but we have to use Patched Odin to Flash successfully.
The only other thing that I can think of off hand, would be to Flash the Canadian CSC on your device ⚠️ This will likely force you to Factory Reset ⚠️ And don't know if that will fix the drain? 🤔
04-09-2022 04:43 PM in
04-09-2022 05:03 PM in
Galaxy SCan you post screen shots of Software Information & The first screen in About Phone ⚠️⚠️⚠️Please Hide the Serial Number & IMEI ⚠️⚠️⚠️
As I have done in my screen shot.
There is no personal information contained in the screen shot of Software Information (2nd screen shot).
Just want to know what your device "thinks" it is.
