Wifi SSID Detection Problem
(Topic created on: 11-06-2020 11:00 AM)
japesech
I am having a problem with my new Samsung S20+ phone.  I am trying to connect to a tennis ball machine so I am not using a router.  It is a direct connection to the machine using the wifi.  I am unable to detect the SSID.  I tried using my computer and it was able to detect the SSID every time.  I did a network reset, rebooted the phone, cleared the cache and reinstalled the app and nothing helped.  Please help.
3 REPLIES 3
keagan
Hi japesech, I suggest you to check if the phone is able to detect other SSIDs when you turn on Wi-Fi on the phone.
SamSungtwo
You may want to try adding the SSID and other information manually by going to WIFI at the bottom click "add network"
xxcoyotte
were to get said program
