05-14-2025 07:09 PM in
Galaxy S- Mark as New
05-15-2025 03:59 AM in
05-15-2025 05:33 AM in
05-15-2025 06:35 AM in
Galaxy SHi TRex818,
We're sorry to hear that wireless charging has stopped working properly after the One UI 7 update. We understand how inconvenient this can be.
Here are a few steps you can try that may help resolve the issue:
Clear system cache. Boot your device into Recovery Mode and clear the cache partition. This can often help after major software updates.
Check for debris. Make sure there’s no dust or obstruction between the phone and the wireless charger.
Use a Samsung-certified charger . Non-certified wireless chargers may have compatibility issues after updates.
Reset wireless charging settings. Go to Settings > Battery and device care > Battery > More battery settings and toggle off/on “Fast wireless charging”.
Test with another charger. If possible, try a different wireless charger to rule out a hardware issue.
Thank you.
05-17-2025 09:32 PM in
