09-21-2021 04:48 PM in
Galaxy ZWhen I first bought my Z Fold3, my apps edge panel was two icons wide as in the photo above. About a week ago it switched to single icon wide skinny thing you see here (also in the photo above). For the life of me I can't figure out how to get my old Edge Panel back! I've tried turning it off and on again with a reboot in the middle. Also tried removing all other panels besides "apps". Both were suggested to me by others but neither had any effect. I don't recall any software updates at the time that this started. Z Fold3 T-Mobile (US) 256gb edition, apps edge panel not pinned. A step by step to find this feature would be very much appreciated if anyone knows! Single column is really cramping my style!
- Tags:
- edge panel
- Z Fold3
09-21-2021 05:00 PM in
Galaxy ZDon't know if you're aware, but this is the Canadian Samsung Members.
There likely isn't any difference between the Canadian & the US Fold, but you may have more luck posting on the US Samsung Members, just because of shear numbers of people.
09-21-2021 06:32 PM in
Galaxy ZEnable Show Recent App. See if it change back to 2 columns.
