a8 sound problems
(Topic created on: 09-01-2018 05:46 AM)
RyanGonzalez
Others
is anyone else getting audio problems with there a8? mine cuts off.
14 REPLIES 14
Others
Is it happening with a specific app? More details is always useful - Did you use the Diagnostics available here on Samsung Members app to test the Speaker?
RyanGonzalez
Others
I didn't use the diagnostics. and it's for all apps
Others
Can you describe more detail about "cuts off"? ie: Does it just stop at any volume setting - Does it sound like static etc
RyanGonzalez
Others
so basically what happens is the audio would be perfect, no problems and from time to time the audio will stop playing for a second and come back. once it starts going it wont stop.
Others
Try the Diagnostics and see what the results are - It's difficult to start looking for a solution when you don't know if it's a hardware issue or a software problem?
RyanGonzalez
Others
the diagnostics said it's normal. but I think its faulty hardware.
Others
If you believe that it's hardware - Samsung Service Center is a good idea - You can always see if a Factory Reset will resolve the issue - Remember to backup your device before if that's what you decide to do.
RyanGonzalez
Others
ok. thanks I'll go there if the problem occurs again
marksydhom
Others
I haven't had any problems with the sound before
