charger port problems
(Topic created on: 09-02-2018 07:05 PM)
ashlie
Others
i have the galaxy A8.. my phone keeps telling me there is moisture in the charger port..
my phone has not been around water or anything. its been in its case.. i keep resettigmng my phone. put my phone in rice for 2 hrs n still nothing.. idk what to do. it wont let me charge my phone either.. bfbbed57-ff6b-4d26-aa07-13348bac27c9.jpg
5 REPLIES 5
Others
You can leave the phone in the baggie of rice for several hours - Don't use a blow dryer with heat - If this dose not work - Service Center 🐧
ashlie
Others
thank you.. iv done this.. 2 hrs i left it in the rice.. still nothing... my phone hasnt even been near moisture or water at all.. idk why its saying this 🙄 😤😖😟😓
Others
I'd leave it in rice overnight - If it still produces the error in the morning - then I'd try a couple of things before going to a Samsung Service Center (assuming you still have at least 40% battery) Boot into Recovery and Wipe Cache - If that doesn't work - Backup your device & Factory Reset (doubtful this will help) - If you have a Wireless Charger that should work - Sorry 🤥
Others
bowl of rice works too! :)
Others
@ashlie
Check this out from Samsung Members US - This was accepted as the solution 🐧
https://us.community.samsung.com/t5/Galaxy-S8-Questions-and-Answers/Galaxy-s8-moisture-detected-won-t-go-away/td-p/110916
In addition to the "accepted solution" - there's another post where someone Booted into Safe Mode & was successful in getting their device to charge.
