My smart tag beeps 4 times after replacing battery - does not connect to phone
(Topic created on: 07-07-2023 02:09 PM)
Mike_from_AZ
Others
My battery died in my smart tag as I tried to replace the battery but only get four beeps every time I put in a new battery.  I tried three new batteries thinking maybe the batteries may be dead but all three were new (bought them today)  I did all the reset instructions and still nothing.  Also I couldn't find anything online about what the 4 beeps mean.  Any ideas??
6 REPLIES 6
RedDogRabbit
Others
If you Open SmartThings and Click on the 3 Line menu > Click on "All Devices" and select the Smart Tag, you should be able to view the Smart Tag's battery level.
What do you see?
Mike_from_AZ
Others
The original battery was dead, so when I couldnt get the smart tag to reconnect I followed the instructions to remove the tag from smart things, so I can't get in to check it.
digital4
Others
If your smart tag beeps four times after replacing the battery and doesn't connect to your phone, it could indicate a few potential issues. Here are some troubleshooting steps you can try:
  1. Check battery installation: Double-check that the battery is inserted correctly, with the positive (+) and negative (-) sides aligned properly. Improper battery installation can prevent the smart tag from functioning correctly.
  2. Reset the smart tag: Some smart tags have a reset button or a specific reset procedure. Refer to the user manual or manufacturer's instructions to find out how to reset your smart tag go for it. Performing a reset can often resolve connectivity issues.
Helenna
Others
Hi, just to confirm have you tried the above troubleshooting steps provided by digital4?
Can you please let us know is your Smart tag issue is resolved?
Mike_from_AZ
Others
Sorry for the delayed response, I got frustrated and put it on the shelf for bit.  No the steps did not work.  Reset will not work.  Press/hold the button for 5 seconds while putting the battery in gave the 4 beeps.
Samsung_bZ0dBlW
Others
I was having same problem.
1. Hold down button and insert battery.
2. Takes more than 5 seconds, more like 30 seconds.
I almost gave up but after 30seconds it came back alive and phone detected it.
