Samsung Led View case not working
(Topic created on: 02-22-2019 08:26 PM)
ExNotes
Others
After the latest Samsung One update the LED Clear view that had to pay for is not working. It is not locking the screen. It is not blacking the screen and overall not doing what it was doing up to before the update? Any idea of a way to fix it?
3 REPLIES 3
Others
Have a look at this post - Especially the last one.
https://community.samsungmembers.com/en_CA?projectId=0&meta=#/post?postId=356632
ExNotes
Others
Thank you...I got it to work. Apparently with the new UI after you update you need to remove the case, turn your phone off for 2 minutes, then turn it back on and install the case again. works fine now!
Others
👍 Good to hear 🐧
