What wireless rear speakers work with Q60t soundbar?
(Topic created on: 03-06-2022 08:34 PM)
DLaw
Others
I know that it lists the swa-8500 as compatible, but is that really the only one?
11 Comments
Joce1
Others
DLaw
Others
That's for the q600a. I'm looking for q60t (2020) compatibility
Helenna
Others
Hi DLaw, SWA-8500S is the only model which is compatible with this sound bar.
DLaw
Others
Well that's disappointing. Would've liked to have a few more options for this soundbar as the swa8500s is hard to come by now
Santini46
Beginner Level 3
Others
More than disappointing I´d say it is a bad "joke" that you can´t find compatible models to complete your sound system for 2 years old models.
I´m in the same situation, Q60T soundbar model 2020, impossible to find rear speakers for it.
I will sell Q60T and replace it by another brand sound system. That before buying newest Samsung soundbar which is compatible with newer rear speakers. Nonsense.
levinfernandes13
Others
Hi ya ,
I have the same sound bar & I am struggling to get a rear speaker here in the UK?
 swa8500s was available only in the US and apparently its discontinued.
Do you know where will I find one ? or is there any other Samsung wireless rear speaker or another 3rd party wireless speaker I will find here in the UK?
DLaw
Others
Hey back,
From what I've seen/heard, you can try other rear speakers but you won't get the same sound or control that you would with the 8500s.
I tried eBay but most times it was either being sold in pieces, without wiring, or damaged at full price (taking advantage of it being a discontinued and unavailable product).
You might have better luck on the UK eBay, but I just gave up on the hunt for this unicorn
WButcher
Beginner Level 4
Others
Considering that Samsung has so quickly discontinued the SWA-8500S for the roughly 2-3 year old HW-Q60T, I will no longer purchase any Samsung product and will recommend the same to others. Cannot trust a company that so quickly discontinues products in an obvious attempt to frustrate people in purchasing entire systems as opposed to upgrade them. Many are searching for the SWA-8500S rear speakers. Many won't purchase Samsung electronics in future as a result.
pishcot
Others
Just bought SWA-9200S Wireless Rear Speaker [2022] and i can confirm that it works with this soundbar (HW-Q60T/EN)
I used to have the SWA-8500S/EN which worked flowless.
Reason for purchasing the 9200 is that i want to upgrade to dolby atmos at some point.
In theory they are better but i can not "hear" the difference.
