Resolved! Solved
fast charge not work
(Topic created on: 12-10-2022 12:34 PM)
hamza_37
Solutions & Tips
 When I put the charger in, it writes Super Fast Charge, then converts to Charge, knowing that the charger has not changed
Habsfan
Solutions & Tips
It is fast charging... just not showing it anymore. To prove it plug in your fast charger it will say fast charging for a few seconds then say charging with a time left. Unplug and plug in a normal charger and you'll see it will say charging and have a longer charging time
10 REPLIES 10
Nylah
Solutions & Tips
Hi, can you please check that the Super fast charging is enabled.
Go to "Settings", then tap "Battery and device care" >> Tap “Battery” >> Tap “More battery settings” >> Tap the switch to activate, "Super fast charging."
It's highly recommended to use Samsung authorized adapters and cables for optimal performance and safety.
hamza_37
Solutions & Tips
Yes, this option is present and activated
samy2022
Solutions & Tips
What is your phone model ? Is it a Galaxy A series ? Because the A series doesn't support super fast charge
hamza_37
Solutions & Tips
a71
pol999
Beginner Level 4
Solutions & Tips
Same with my s22 ultra wont fastcharge animore since update
RedDogRabbit
Solutions & Tips
It may just be a bug in how Super Fast Charging is reported.
Others who have noticed this not being displayed, are saying that their devices are charging at the same speed as with Super Fast Charging, it's just not being displayed that it is.
hamza_37
Solutions & Tips
I think it's a general problem
Navi1529
Solutions & Tips
Yes its the same the text does not display eventhough it is fast charging or super fast charging. This happened to my s22 ultra after updating to oneui 5
hamza_37
Solutions & Tips
Yes, this error happened with the new update
