Resolved! Solved
Lost Battery level Icon
(Topic created on: 04-17-2024 01:05 PM)
Tlew
Solutions & Tips
I have an S23fe and have lost the battery level icon in the upper right of my home page. How can I get it back?
Ray1
Expert Level 4
Solutions & Tips
Do you have Good Lock installed?
If you do go to Quikstar, visibility of icons, system icons and enable battery icon
8 REPLIES 8
Helenna
Solutions & Tips
Hi Tlew, are you talking about the battery percentage icon?
If yes, please go to settings > tap on notifications > Advanced settings > Show battery percentage > turn it on. Now you can check if your battery percentage level is enabled.
Thank you.
Tlew
Solutions & Tips
I currently have the percentage showing (which I want to keep), but there is no icon showing ... which I also want. What you suggested did not bring up the icon
Ray1
Expert Level 4
Solutions & Tips
Tlew
Solutions & Tips
BINGO ! ... It worked. THANK YOU!! Is there a way to reposition it (move it to the left of the wi-fi signal)?
Tlew
Solutions & Tips
And make it just a weekend bit bigger?
Ray1
Expert Level 4
Solutions & Tips
No way to move it or make it bigger that I have seen
Tlew
Solutions & Tips
Fair enough. And I said a "weekend" bigger. Duh !!! I meant a WEE bit bigger. But I guess you realized that. Thanx again !
Helenna
Solutions & Tips
Hi Tlew, that's good to hear that the above steps worked for you. Please write back to us if you require any further assistance in the future.
Kindly take the time to accept the comment that you find helpful as a solution by clicking on 3 dots and tap on "Accept as solution" and helps others with the same query.
Thank you.
