Resolved! Solved
Low Battery Notification on Tab A7 Lite..
(Topic created on: 12-18-2022 12:52 AM)
Atsirt
Solutions & Tips
Looking to turn on the low battery notification on my Samsung Tab A7 Lite, does this tablet offer this feature and if so, where?
Thank You!!
Solutions & Tips
You can use Bixby Routine (Modes and routines).
Create a new routines called Low Battery.
Conditions:
If Battery level below 15%
Then Show custom Notifications
See my screenshot.
I did that for fully charge too.Screenshot_20221218_075311_Modes and Routines.jpgScreenshot_20221218_075305_Modes and Routines.jpgScreenshot_20221218_075232_Modes and Routines.jpg
7 REPLIES 7
RedDogRabbit
Solutions & Tips
Don't know if your Tab has a Low Battery Notification, but I imagine that it might.
You could Search in Settings for "Battery" and see if it's an option?
I use this app from the Play Store for "Charged", "High Temperature" & "Low Battery."
All 3 are user customizable, ie: if you want to be Notified when the battery reaches 80% of charge, you can set it to 80%. In my case I have 100%.
You can also select different Notification Tones to ale you of the different states.
Atsirt
Solutions & Tips
I did check in the battery section of settings and found nothing unfortunately. Im going to check out this app you mentioned! Thank you!!
Solutions & Tips
Conditions:
See my screenshot.
Atsirt
Solutions & Tips
Will try this now 😊
Atsirt
Solutions & Tips
I got it set 👍 thank you
Helenna
Solutions & Tips
Hi Atsirt, as suggested by Tallman you can try using Bixby routines to show the battery notification on your device and see if it works for you.
Thank you Tallman.
desamuel
Solutions & Tips
How can till you the is seata battery is not charge this troe internet seats sam time the fone no good or the tablet no good rescall
