Resolved! Solved
S24U S-Pen problems
(Topic created on: 01-29-2024 07:29 PM)
Kaler
Solutions & Tips
Anybody else having problems with s24 ultra S-pen. I tried this diagnose from here with s Pen, just moved it across the screen line by line, it just stopps working and have to do it pressing a little hard. And it's hard to use it at an angle. Have to hold it directly straight on the screen.
Resolved!
33 REPLIES 33
Kaler
Solutions & Tips
Yes
Techhead
Solutions & Tips
That's why
Kaler
Solutions & Tips
Does it really effect it that much
Techhead
Solutions & Tips
Depends. I have one on mine and it doesn't seem to affect it.
Kaler
Solutions & Tips
Got it from ESR, had great reviews
Techhead
Solutions & Tips
I also have the ESR one on mine. The clear one. I haven't notice any S-Pen issues, but I also haven't used the S-Pen much
Kaler
Solutions & Tips
I ave this onec5009228-211d-47b5-b66c-3eb505988120_1000068340_1706556867.jpg
Techhead
Solutions & Tips
Exactly the same one I have. I am heading out the door. I will test my S-Pen later with the diag tools and see if it works everywhere on the display.
justmenan
Beginner Level 4
Solutions & Tips
me too just like that.  having issues straight holding only, too many mistakes typing about ready to throw it at the wall. always had samsung spens this one is awful
GG2
Expert Level 3
Solutions & Tips
I have the ESR and it does affect the spen, remove the case and you will see your spen works perfectly
