Resolved! Solved
S24U S-Pen problems
(Topic created on: 01-29-2024 07:29 PM)
Kaler
Solutions & Tips
Anybody else having problems with s24 ultra S-pen. I tried this diagnose from here with s Pen, just moved it across the screen line by line, it just stopps working and have to do it pressing a little hard. And it's hard to use it at an angle. Have to hold it directly straight on the screen.
Techhead
Solutions & Tips
It's been mentioned that MagSafe messes with the S-Pen. That we already know.
I just did mine. No issues anywhere, but I did have to press a bit. That's prob my screen protector causing that though.
33 REPLIES 33
Thology2011
Solutions & Tips
Do you have a screen protector 🤔?
Kaler
Solutions & Tips
Nope
RedDogRabbit
Solutions & Tips
I had a very similar issue on my old S9+ or S10+ failed the Diagnostics, and I was ready to visit a Samsung Service Centre, but I Factory Reset & it solved the issue permanently.
So, if it's not a hardware issue, a Factory Reset may well fix it.
Kaler
Solutions & Tips
I just got the phone today, that was the first thing I did after turning on the phone, Run a full diagnostic
DonPaco7
Solutions & Tips
Even if new, is always good practice to do a reset, just in case 👍
Kaler
Solutions & Tips
Ok will try that
DonPaco7
Solutions & Tips
Did it work ?
Kaler
Solutions & Tips
Yeah, its better now but still have to hold it straight on the screen, cant hold it on an angle.
GG2
Expert Level 3
Solutions & Tips
Are you using a case with magsafe ?
