08-02-2021 09:15 AM in
Wearables
08-02-2021 09:31 AM in
WearablesHi, I suggest you unpair and repair the earbuds. You can use your Galaxy Buds, Galaxy Buds+, Galaxy Buds Live, or Galaxy Buds Pro when watching TV so you can control the volume without interrupting anyone nearby. If your earbuds have not been paired to another device, simply open the case to put them into pairing mode. If they are already paired to another device, insert them into your ears and hold both touchpads for a few seconds until they enter pairing mode. Navigate to the Bluetooth audio device list on your TV, and select the earbuds to pair with.
Please try the below path to connect:
Select Home, select Settings, and then select Sound.
Select Sound Output, and then select Bluetooth Speaker List.
