Samsung A15 With 35W PD Power EB_TA220 Not charging
(Topic created on: 02-03-2024 09:50 AM)
Motaz1989
hi , i have Samsung A15 With 35W PD Power EB_TA220 Not charging
All devices charge quickly with the supercharging feature, but my device does not charge at all
7 Comments
RedDogRabbit
Try a different Charging cable..
Also, Open the Samsung Members app & Click on Support > Phone Diagnostics & run the Diagnostics for the USB Charging Port & the Battery, See if you get any error messages?
Motaz1989
He returned to work, I don't know what the problem is , super fast
Motaz1989
However, sometimes it recognizes the charger as a device that has been connected via USB, and sometimes it does not recognize it at all, and other times it charges very quickly, and sometimes it disconnects the charge and returns.
RedDogRabbit
It sounds like one of 3 things.. either the USB Charging cable, Charging Block or the USB Charging Port.
While it's easy to switch the Cable & Charging Block, and if you can rule those two out, then that leaves the USB Charging Port as the culprit.. could it have a loose connection internally in the phone? It's possible.
Try wiggling the cable at both the Charging Port & Charging Block ends, see if it starts / stops charging?
Motaz1989
It can't be as you said because it's all completely new pieces
RedDogRabbit
Well, you could try to test the Cable & Charging on another device, or try a different Charging Cable & Charging Block on your A15.
Did you run the Diagnostics for the USB Charging Port?
Even brand new accessories, can have a manufacturer's defect.. maybe rare, but still possible.
Helenna
Hi, we are glad to see that you found the required information.
Please get back to us if you require any further assistance in the future.
Thank you.
