Im having problems connecting my pen to my Samsung galaxy note 9 phone...anyone
(Topic created on: 10-18-2024 04:33 AM)
foxylibragurl80
Galaxy Note
Im having issues connecting my pen to my Samsung galaxy note 9 phone it says can't connect anyone help thxs
1 REPLY 1
Helenna
Galaxy Note
Hi foxylibragurl80,
If you're having trouble connecting your S Pen to your Samsung Galaxy Note 9, here are some steps you can try to resolve the issue:
Please restart the device: Sometimes, a simple restart can fix connectivity issues. Try turning off your Galaxy Note 9 and turning it back on.
Reinsert the S Pen: Remove the S Pen and reinsert it into the slot to ensure it's correctly seated. Wait a moment to see if the phone recognizes it and prompts you to reconnect.
Ensure that Bluetooth is enabled on your device since the S Pen uses Bluetooth for advanced features (remote control, etc.). Go to Settings > Connections > Bluetooth and make sure it is turned on.
Reset the S Pen: Go to Settings > Advanced Features > S Pen. Look for the option to reset the S Pen. This can refresh the connection between the S Pen and the phone. Follow any on-screen instructions to complete the reset process.
Thank you.
