Note 8 battery drain issue
(Topic created on: 02-20-2019 06:17 PM)
jeet
Beginner Level 4
Galaxy Note
Anyone else having this issue.  I've to charge phone couple of times in a day after recent update.
5 REPLIES 5
Galaxy Note
You can try (probably should after every OTA) Boot into Recovery and Wipe Cache 🐧
jeet
Beginner Level 4
Galaxy Note
Thanks that did help
Galaxy Note
If you still have battery issues - Then I'd backup your device with Smart Switch - Move everything that you want or need to the external sd card & Factory Reset - I was running the US One UI beta & I Factory Reset before I Odined to the Canadian Stable version of One UI - And Factory Reset again be I set up the phone - Getting decent battery life 🐧
Moderator_
Galaxy Note
Thanks @ShaggyskunkS9P for the recommendations! 😊
Cheers,
Sabrina
Nickoy1
Galaxy Note
there was a period I had a very terrible battery drain but I think it was an app... after deleting it things were better. Still the note 8 does drain battery alot even not in use.
