Resolved! Solved
note 8 battery maintenance missing.
(Topic created on: 04-03-2019 09:59 PM)
lpo84
Galaxy Note
I have discovered that the battery maintenance is now called device care.
I used to have it in my edge screen with oreo. After pie it went missing.
I figured out that if you open device care in the main settings page + tap the three dots there is an option says. Show icon on app screen.
You can then add it to your app edge screen. Witch is what i had originally had.
2 Solutions
Galaxy Note
You should be able to add it (Device Care) to your Home Screen - Which is what I do 🐧
QP
Galaxy Note
They removed after the update to OneUI. I believe they did mentioned before. That it will be remove from Edge Panel.
4 REPLIES 4
Galaxy Note
lpo84
Galaxy Note
that is what I'm talking about. i just like it in my edge panel.
lpo84
Galaxy Note
works well now they way i have it.
QP
Galaxy Note
