Note9 Popping sound, not fixed.
(Topic created on: 03-07-2019 08:32 AM)
CHMultimedia
Galaxy Note
My Note9 finally came back to me today. I had hopes they had fixed my popping sound problem I wrote about here: https://community.samsungmembers.com/en_CA/profile_post?categoryId=10004&postId=529689
Unfortunately, all they did was replacing the microphone and the earphone?!
I repeat that my problem is not that the device has a crackling sound when playing audio and video content. It is a physical problem that also occurs when the device is turned off. Turned on, turned off... this issue is present.
I feel very disappointed to have wasted a week without a phone, to find out my issue was misunderstood and ultimately not fixed.
I'll just try to live with it and if the issue worsens, I'll try again to get it fixed
4 REPLIES 4
CHMultimedia
Galaxy Note
Just looked back at the emails I had. The automatically generated Online Service Request Information e-mail had the following info:
Model Number / Numéro de modèle : SM-N960WZBAXAC
Serial Number / Numéro de série : (REDACTED)
Product Symptoms / Symptômes du produit : Call Quality / Sound/Sound Problems/Head Phones not working
So yes, my problem was definitely misunderstood
CHMultimedia
Galaxy Note
I think a video is in order haha.
Now I'm off to restore my data. Should be done pretty quickly, then I'll catch up to what's been going on in the meantime.
Bing
Galaxy Note
if u have Samsung store near u they can fix it within hours
CHMultimedia
Galaxy Note
See the link and you'll see why this won't work
