Adjust alarm volume from the volume drop down menu
(Topic created on: 11-20-2017 11:07 AM)
s23curator
There's a major flaw in the S8's alarm app.
Everytime I set a new alarm it creates a new profile with default settings which include the default alarm volume (which is obviously too loud, I almost have a heart attack everytime I wake up!);
a default alarm tone, which is dreadful;
plus theres no quick adjust seeing from the volume drop down panel when you press the volume keys, which is annoying.
so my request here is to create a personalized alarm setting, so that Everytime I set an alarm I don't have to change the volume or the alarm tone from the defaults.
Also Samsung should add the volume adjustment settings in the volume adjustment drop-down menu389df680-5e8a-41af-a95a-5f25d79cfe8b.jpg
4 Comments
Jmak
When setting alarm in alarm app, if you use volume button you'll see alarm volume option.
s23curator
for that I have to go specifically into the app, then select the specifit alarm time and then and only then can I adjust the volume. that's a long process. other android phones have this facility on the homescreen.
Moderator_
Hey @s8curator, thanks for the feedback. As always, I'll be sure to pass this onto the rest of the team! :)
-Nick
ThePhoenix
This thread is from 2017.
Its now 2024 and the problem still stands for my S23...
