Android auto and weak cell signal S22 Ultra
(Topic created on: 04-26-2022 02:05 PM)
iFlYSoLo
So I noticed this a couple times now..when I am.using android auto via USB, my reception is horrible, sits at H.. if I unplug on the same route, back up to 5G..I drive a kia and this has never happened.
Thoughts?
15 Comments
RedDogRabbit
Mercedes? lol 😂
Yeah that's weird, wouldn't think that a USB connection would affect the signal strength.
Have you tried a different USB cable?
iFlYSoLo
Lol no solution reqd on a budget..
This is the cable from the box so... it's quite annoying because I could not play Spotify!
RedDogRabbit
I'd probably still try a different USB cable, if you have one. Sometimes what's in the box, isn't the best?
iFlYSoLo
OK I can try that... but I like boxes lol
RedDogRabbit
I know that cats love boxes! 😉
iFlYSoLo
But I am not a kitty..
RedDogRabbit
iFlYSoLo
RedDogRabbit
Is this the same with your S22?
It's also possible that it *COULD* just be a coincidence, if a cell tower was out, or some other network issue, however unlikely that may be?
