Battery data reset
(Topic created on: 05-29-2025 04:01 PM)
This might help with the battery drain issue
Go to your phone app and type in *#9900#
Find "Batterystats reset": Scroll down the menu and find the "Batterystats reset" option.
Tap the option: This will erase previous battery usage data and restart the battery learning process.
Might take a week to relearn your usage to optimize your battery.
*Don't play around with the other settings, I won't be responsible if you mess up something else on your phone.*
3 REPLIES 3
Helenna
Hi defconphil,
Thanks for the tip! TYes, the menu is part of Samsung’s debug settings and not meant for general use. While resetting battery stats can sometimes help, please be very careful not to change anything else in that menu.
Actitan
Is it possible to do this on galaxy tablet that doesn't have a phone app?
PatS6969
Are there any of the *# codes to test why a phone freezes then when you press the power button and the down volume it shuts down to an upload mode. I got a Samsung Galaxy A6+ pro A605F.
