Battery drainage
(Topic created on: 07-07-2024 05:52 AM)
Chiggy
Anyone having issue with battery dropping so fast on s24 ultra? What can be done to fix it?
14 REPLIES 14
Chiggy
So my AOD is just time, date with black screen no wallpaper. I thought that doesn't drain much.
RobertZ
One thing that extends battery life a bit is to lower your screen brightness as much as possible.
Thology2011
Mines was doing the same. I did a reset and cache clear and the battery life seems back to normal.
Helenna
Hi Chiggy,
 We are sorry to hear the battery draining issue on your device.
You can monitor and extend its battery life or use a Power saving mode to get the most out of it. You will never be stumped about your phone's battery life again.
You can try booting your device into Wipe cache partition. This will not erase personal data on the phone. It deletes temporary cache files in the phone.
Turn off the device > Press and hold the Volume Up key and the Power Key > When the Android logo displays, release all keys.(("Installing system update" is displayed before displaying the Android system recovery menu options) > Press the Volume down key several times to highlight “wipe cache partition.” > Press the Power key to select > Press the Volume down key to highlight > “yes” and press the Power key to select. When the wipe cache partition is complete, “Reboot system now” is highlighted. Press the Power key to restart the device.
Please visit the link given below and check if it helps to solve battery draining issue on your device.
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-get-the-most-out-of-your-battery/
Thank you.
Chiggy
How often should I do that?
